Hi folks,
I’m currently using an iRule to log cipher usage. It works great. However, I need to modify to include the Virtual Server name in the log entry. Here’s what I’ve been using:
if { [info exists logged] && $logged == 1 }{
Do nothing. Already logged for this connection
set host [HTTP::host]
set useragent [HTTP::header "User-Agent"]
set logged 1
log local0. "[IP::client_addr] - [SSL::cipher name] - [SSL::cipher version] - [SSL::cipher bits] - [HTTP::header "User-Agent"]"
…and here’s what I was going to try to get the virtual server name added:
log local0. "[virtual name] - [IP::client_addr] - [SSL::cipher name] - [SSL::cipher version] - [SSL::cipher bits] - [HTTP::header "User-Agent"]"
Does anyone have any thoughts on whether or not that will work? If not any suggestions?
