Checking SSL Certificates using iControl REST API
Hi guys,
I’m looking for a way to check if the SSL certificate has expired using iControl REST API. I have already found a way to check all certificates that can be used in SSL Client/Server Profiles with Virtual Servers mgmt/tm/sys/file/ssl-cert endpoint and these are all certificates that can be found in System >> File Management >> SSL Certificate List.
I’m also very interested in checking the certificates that are using for config sync between the BIG-IP devices. This is the part where I’m having some issues. I have found the mgmt/tm/cm/cert endpoint that contains dtca.crt and dtci.crt. I’m wondering what these certificates are used for. Can somebody shed some light on it please? In the documentation I have also found mention of server.crt and client.crt that can be found in the /config/httpd/conf directory of the BIG-IP file system. But I haven’t managed to find any iControl REST API endpoint that would return some information about these certificates, and I’m not sure what they are used for either.
no totaly responding to you question (the rest par at least) but there is a sol describing various certificate used : Overview of BIG-IP device certificates (11.x - 12.x)
