Hello All,
I am new to iRules, hope you can help me out. Thank you in advance.
The use case is that I want to double-check on a specific data group availability, hence to check whether it exists or not. AFAIK the data group from iRule point of view is called classes, and I am aware about the catch command as well, so was wondering about something like the following, just not sure what command(s) to use in place of ???:
if {[catch {class ??? my_data_group_name}]} {
# The class does not exist
# The class exists
