Do anyone know how to check and see if a device has a peer or not?
Thanks,
Thanks,
Hi Joe,
You can check the failover.isredundant DB key:
tmsh list sys db failover.isredundant
or in iControl: DevCentral
Aaron
Ok. Thanks that helped.
Say that the device is part of a redundant pair but there is no actual pair there. The device is just set up to have a redundant pair.
Would their be a way to check to see if that peer is there or not?
I had thought about using the get_list() from iSessionPeerDiscovery and I was thinking that if it returned no list then that means there is no peer there even though the device is set up as a redundant pair.
What do you think?
