Hello Everyone,
I would like to change a page’s language explicitly - regardless of what is sent in the HTTP header. A practical example is that I need to show English by default and have a link in the page to French language interface. I need this both in the login page, and in the webtop.
I also need to detect what language is being displayed and change URLs based on that.
Any help is appreciated.
Thanks,
Farsheed
While I have not tried this, I would think you could use “HTTP::header replace” to modify the “Accept-Language:” portion of the HTTP Header in all requests, specifying ONLY the language you want.
HTTP::header replace []
Good luck!
David
David’s right on the money with HTTP::header replace:
HTTP::header replace "Accept-Language" "en"
This can be used in a request or response, but in this case you’d be replacing a request header. As for performing URI-switching logic based on the requested language:
switch [HTTP::header "Accept-Language" {
"en" {
HTTP::uri "/en/something/"
"fr" {
HTTP::uri "/fr/something"
You mentioned a “webtop”, so if this is being used with APM, replace HTTP_REQUEST with ACCESS_ACL_ALLOWED.
