Changing Cipher settings of Multiple Client SSL Profiles associated with a VS
Hi All,
I have a VS with 3 client SSL profiles mapped. When i try to update the cipher settings on any one of the profiles, i get error as below:
Error: selected client ssl profiles do not match security policies.
In order to resolve this, i would have to remove the association of profile with the VS, perform the change on Client SSL profile and then associate it back.
Any idea why does this happen ?
Thanks in advance,
Prince, have you seen this solution article?
SOL13452
This suggests using a base SNI/TLS profile.
Hope this helps,
N
