Changes Pending
Is there a way to find out what changes are pending when you see changes pending state?? Either through cli or GUI???
They only way I know is to compare the configuration in ie.
/config/bigip.conf
and
/config/bigip_user.conf
. The dashboard in the web ui also has some information if you have audit logging enabled, but it’s not much.
You could also, but I haven’t tried this one myself, get an scf file from the peer unit och compare it with show sys config-diff.
Update:
Just tried it and it does the job. However, I would probably just go for notepad++ and compare the scf files as it’s more clear.
To save an scf file, run
tmsh save sys config file [scf file name]
. That will create single config file (compiled from all different config files on your system).
/Patrik
