Change Case on Append IP iRule
I have a working iRule that appends the IP address on a client request. However, it is case sensitive. The URL must have “login.aspx” in the URL exactly for this to work, but I would like to make it work with “Login.aspx”, “LOGIN.aspx”, etc. Does anyone know how to change the case of the incoming URL ?
set client [IP::client_addr]
set request [HTTP::uri]
if {$request contains “login.aspx” and $request contains “?”}
{HTTP::uri “[HTTP::uri]&IPAddress=[IP::client_addr]”}
elseif {$request contains “login.aspx”}
{HTTP::uri “[HTTP::uri]?IPAddress=[IP::client_addr]”}
Thanks.
You can use ‘string tolower “original_string”’ to set a string to lower case. You can eliminate some of the variables as well:
      Check if the path, set to lower case, ends with login.aspx
     if {[string tolower [HTTP::path]] ends_with "login.aspx"}{
         Check if there is a query string
        if {[string length [HTTP::query]]}{
            Append the IPAddress parameter with the client IP to the existing query string
           HTTP::uri "[HTTP::uri]&IPAddress=[IP::client_addr]"
            Append the IPAddress parameter with the client IP to the path
           HTTP::uri "[HTTP::path]?IPAddress=[IP::client_addr]"
For an example URL:
http://www.example.com:80/path/to/file.ext?param1=value1&param2=value2
These commands return the following values:
HTTP::host (Click here) - www.example.com:80
HTTP::path (Click here) - /path/to/file.ext
HTTP::query (Click here) - param1=value1&param2=value2
HTTP::uri (Click here) - /path/to/file.ext?param1=value1&param2=value2
Aaron
I will give this a try.
Thank you very much for your response.
