Certiicate Required
I would like to create a public website, but require one of the company ssl certs to load the site. Does anyone have any examples on how to do this.
Here is an example.
I want to go to https://place.company.com. I want to check to make sure the user has the cert installed on his local machine and then load the site. IF the user doesn’t have the cert, I want to send him to a different UI.
Thanks for the help.
Assuming you’re the issuer of the cet, I think you’d want something like this:
  if { [SSL::cert issuer] eq "your_company" } {
    pool appropriate_ssl_pool
    HTTP::redirect "http://www.your-chosen-redirect-domain.com"
Hope this helps,
-Colin
This is what I have
if { [SSL:Thawte Server CA:] eq “Thawte Server CA” } {
pool secure.sitename.com
HTTP::redirect “http://www.your-chosen-redirect-domain.com”
It gives the following error.
01070151:3: Rule [_require_cert_sites] error:
line 2: [undefined procedure: SSL:Thawte] [SSL:Thawte Server CA:]
Well, first of all, the rule is a little off. Try this:
  if { [SSL::cert issuer] eq "Thawte Server CA" } {
Second, what information in the cert is it that you want to use to identify whether or not the client has the right cert installed?
Thanks,
-Colin
Here is what i am bascily looking for.
I have a site, its called https://csr.sitename.com. This is a public site, but I only want users that have one of our certs installed to load the site.
I though I could create a rule to check to see if the browser has the cert, and if it does allow the user to see the site, and if not, send them elsewhere.
Here is what I have from your last post.
if { [SSL::cert issuer] eq “Thawte Server CA” } {
HTTP::redirect “http://www.yahoo.com” }
I recevie the following error.
line 2: [wrong args] [SSL::cert issuer]
I am not sure what part of the certificate I Should look for. I got the rule to work with no errors, but the site will not load with the cert installed.. Any other ideas?
