We deployed a staging e-payment application, using a Virtual Server with these properties : port : https protocol profile : mptcp-mobile-optimized HTTP Profile : XFF SSL Profile : 2 certificates - The issued certificate & a second certificate with Default SSL Profile for SNI
SNAT Pool : ip in the same subnet as nodes. Pool : 2 pool members with port 7010 I’m using public certificates (signed by CA Verisign G5 & CA Symantec G4)
the web page is displayed correctly, & SSL checks says all is ok (tested with "; & "
the actual issue is that transaction doesn’t pass over https (in http it works fine)
here’s the error message relived from client side : -An exception occured in HTTPProcess sendMessage. Exception: javax.net.ssl.SSLHandshakeException: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target. - doPost exception encountered. Exception: java.lang.NullPointerException.
I made a quick test with sslchecker.com and it says that the Root CA is missing. Please try to adjust your chain and include the GeoTrust Global CA as well. If your client then still throughs an error, please verify the clients trust store and maybe install the required GeoTrust Global CA.
This is due to missing root and intermediate chain in the java/similar key store. you need to import the Symantec/Verisigin certificates, we faced the same issue last week and fixed it by importing complete root and intermediate chain
