First time question. Is there a way to do a mass distribution of certificates either using enterprise manager or scripting? I have a new certificate that is needed to be deployed across several F5 LTM devices using version 11.5.1
It’s not very refined, but when I need to upload certificates to multiple BIG-IPs, I follow this process. I’m wanting to put it into a PowerShell script, but haven’t had the time to devote yet). Hopefully it helps if you try to put together a script to do this.
IMPORT / INSTALL SSL CERTIFICATE & KEY THROUGH TMSH
- SCP (using WinSCP or other file transfer client) CRT and KEY files to the server
/config/ssl/ssl.crt -
/config/ssl/ssl.key
- Install the certificate and key using the same [NAME]
install /sys crypto cert [NAME] from-local-file /config/ssl/ssl.crt/[FILENAME] -
install /sys crypto key [NAME] from-local-file /config/ssl/ssl.key/[FILENAME] - Test to verify certificate and key were installed
list / sys crypto cert [NAME] -
list / sys crypto key [NAME]
- Save the config
save / sys config
Links I used in my research
