Hi Guys,
I am using SNI for 2 URL with certificates terminated in F5 using 1 VIP. abc.com - certificate common name is abc.com XYZ.com - certificate common name is XYZ.com
iRule configured for both URL’s for redirection. When I access abc.com, website shows connection secure. However when I access XYZ.com, website shows connection not secure.
When I check from https://www.sslshopper.com/ for XYZ.com to verify common name, result shows below. The hostname (XYZ.com) is correctly listed in the certificate.
Do I need to request for SSL cert with small caps xyz.com and update certificate? I also thinking will it solve if I use tolower command of iRule?
