Certificate and key related to the F5 devices.
Certificate and key related to the F5 devices. I just wanted to know if the F5 certifiacte and key need to be of the exact same name or the names can differ…?
IF you have the same name, then show up as both RSA certificate & key under the SSL list. This is visually good. :slight_smile: The names can be different also (while importing) as long as you know what matches what and make the appropriate selection under your SSL profiles.
that helped. I have a situation like.. abc-rq.dd.com cert renewal request from my companies workorder creation team.. but on the device I see only abc.dd.com as cert and key.. but there is one other entry for abc-rq.dd.com as key only.. the cert entry for abc-rq.dd.com exactly is not found.. little confusing
If you do a curl to the domain that has the SSL terminated on the F5, you should be able to identify the cert domain.
