I am looking for a way to get early warnings of certs expiring
A search on AskF5 for certificate expiration leads to:
SOL7574: Monitoring SSL certificate expiration on the BIG-IP system
checkcert -h
Usage: checkcert
In its main form (no arguments), checkcert examines all certificates
/config/ssl/ssl.crt and will log any expired ones to local0.warning
Usage: checkcert [-v]|[-[s|o|e]] [-k num] [-d directory] [-f file]
-v Verbose mode (forces -o)
-k Skip bundles with more than certs (default=20)
-f file Check
-d dir Check all files in /ssl.crt
Only one of these options may be specified:
-s log to syslog LOCAL0.WARNING (default)
-o log to stdout
-e log to stderr
Aaron
You can also use custom SNMP traps to do this, since there is a message you can capture from /var/log/ltm warning about cert expiration.
The procedure is explained in SOL3727:
404 Page not found | BIG-IP Documentation Click here
My entry in the user_alert.conf file looks like this:
alert EXPIRING_SSL_CERT "Certificate (.*) in file (.*) will expire on (.*)" { snmptrap OID=".1.3.6.1.4.1.3375.2.4.0.500" }
The OID is “made up” according to the SOL.
Denny
