Catchall VIP that supports TCP and UDP?
Is it possible to create a VIP that has 0 as the VIP port and 0 as the server port and supports both TCP and UDP? Say by not assigning it to a specific protocol?
Or would I need to create two catchall VIPs, one that supports TCP and one that supports UDP? If so, can they share the same virtual ip?
Atoth, you can create a forwarding IP vs with All Protocols but this has no concept of pools so is just a forwarder…as the name suggests. Else, if you need a pool then you can select All Protocols with a performance layer 4 vs too, with downsides re layer 7 visibility.
Hope this helps,
N
I think that might. I’ll give it a try. Thanks.
