Catch specific SSL errors/failures???
Hi there
One of the requirements that I’ve been given is to try and catch certain SSL errors and return a more friendly error page, rather than the browser default…
A couple of the examples that have come up so far are:
* A User attempting to connect to a VIP that is enforcing client SSL certficiates but doesn’t have a valid Client SSL certificate installed…
* A user attempting to connect to a VIP with an expired Client SSL certificate
* A user connecting with a very old SSL Version or Cipher…
Now the last one is nice and easy as there’s plenty of reference code on the Wiki…
However I’m struggling with 1 & 2 above…
Any pointers or ideas???
Cheers
Gav
not sure whether SSL::verify_result is usable.
SSL::verify_result wiki
[root@ve1023:Active] ca2012  b virtual bar list
virtual bar {
   snat automap
   pool foo
   destination 172.28.19.79:443
   ip protocol 6
   rules myrule
   profiles {
      http {}
      myclientssl {
         clientside
      tcp {}
[root@ve1023:Active] ca2012  b pool foo list
pool foo {
   members 200.200.200.101:80 {}
[root@ve1023:Active] ca2012  b profile myclientssl list
profile clientssl myclientssl {
   defaults from clientssl
   ca file "chain.crt"
   peer cert mode request
[root@ve1023:Active] ca2012  b rule myrule list
rule myrule {
        if {[SSL::verify_result]} {
                HTTP::respond 403 content [X509::verify_cert_error_string [SSL::verify_result]]
[root@ve1023:Active] ca2012  curl -ik https://172.28.19.79
HTTP/1.0 403 Forbidden
Server: BigIP
Connection: Keep-Alive
Content-Length: 32
application verification failure
[root@ve1023:Active] ca2012  curl -ik https://172.28.19.79 --cert certs/client.crt --key certs/client.key
HTTP/1.1 200 OK
Date: Mon, 16 Jan 2012 17:32:45 GMT
Server: Apache/2.2.3 (CentOS)
Last-Modified: Fri, 11 Nov 2011 14:48:14 GMT
ETag: "4183e4-3e-9c564780"
Accept-Ranges: bytes
Content-Length: 62
Set-Cookie: BROWSER=MOZILLA%20INTERNET_EXPLORER%20CHROME; path=/
Content-Type: text/html; charset=UTF-8
One of the keys to this working is that you need to change the client cert mode from require to request. This allows LTM to complete the SSL handshake without a valid client cert.
You should probable also add a check that [SSL::cert 0] ne “” before checking SSL::verify_result doesn’t return 0 for an invalid cert.
Aaron
Aaron/Nitass
Again, very impressed and thanks again for the above pointers…
Will see what i can work up tomorrow :slight_smile:
Cheets
Gav
You should probable also add a check that [SSL::cert 0] ne “” before checking SSL::verify_result doesn’t return 0 for an invalid cert. since it does not return 0, bigip should respond with 403, shouldn’t it?
[root@ve1023:Active] ssl  curl -ik https://172.28.19.79 --cert ssl.crt/default.crt --key ssl.key/default.key
Server: BigIP
Content-Length: 23
self signed certificate
Sorry for the weird formatting on the above 2 posts… I’ve tried several edit’s to get it correct, but it’s having none of it…
Gav
That looks like a good start Gavin. Can you try moving the ifile command to RULE_INIT and use subst to force evaluation of the variable?
Retrieve the HTML
set static::error_page [subst [ifile get error_page_html]]
Also, can you try editing your post and put the iRule in [ code ] [/ code ] blocks (without the spaces in the code tags) to preserve the line indentations in the iRule?
Nitass:
I’m not sure what [SSL::verify_result] returns if no SSL cert is present in the request or for the SSL session, so I was thinking it would be better to check for that before using any SSL commands.
Thanks, Aaron
Double post…
Aaron
Did try putting code tags in, but just kept breaking… I guess could be due to the HTML tags in the include page…
I tried adding your line to the RULE_INIT block, but got the following error:
Jan 18 13:57:24 tmm err tmm[9144]: 01220001:3: TCL error: /Common/Catch_SSL_Errors - can’t read “failure_result”: no such variable while executing “subst [ifile get error_page_html]”
Jan 18 13:57:24 tmm err tmm[9144]: 01220006:3: RULE_INIT for rule /Common/Catch_SSL_Errors failed
However that did send me in the right direction… I’ve kept the error_page variable in the HTTP_REQUEST block, and have wrapped it inside a ‘subst’ tag on the HTTP::respond lines… E.g:
HTTP::respond 403 content [subst $error_page] “Content-Type” “text/html” “Connection” “Close”
I did try the code without the SSL::cert count, and it returns a result code of 50 - ‘X509_V_ERR_APPLICATION_VERIFICATION: application verification failure’. I chose to wrap it in a count as it gives me an easy way of picking out where they don’t have a client cert, as that’s our typical failure method. Plus it saves some processing time I guess…
Latest copy of the rule is below…
Going back to your suggestion of putting the ‘ifile get’ in the RULE_INIT section, are there any advantages/disadvantages of this?
Cheers
Gav
when RULE_INIT {
Debug Logging
set static::CatchSSLErrorsDebug 1
Get the Error Page HTML
set static::error_page [ifile get error_page_html]
v10.1 or higher
Redirect any client HTTP request with no client certificate or with a cert which is not correctly
validated against the trusted root certificate specified in the client SSL profile.
when HTTP_REQUEST priority 10 {
if {$static::CatchSSLErrorsDebug == 1} { log local0. “CatchSSLErrors HTTP Request:” }
Return the Logo if requested.
if { [HTTP::uri] ends_with “logo-act.png” } {
if {$static::CatchSSLErrorsDebug > 0} { log local0.info “Returning Logo…” }
HTTP::respond 200 content [ifile get act_logo_png] “Content-Type” “image/png” “Connection” “Close”
event disable
return
Hide the SSL:: command’s from the iRule parser
so the iRule can be used on a non-client SSL VS
set cipher_cmd “SSL::cipher version”
set count_cmd “SSL::cert 0”
set verify_cmd “SSL::verify_result”
set failure_cmd “X509::verify_cert_error_string”
Get the error page
set error_page [ifile get error_page_html]
Check if the client used an SSL cipher and it’s not “none”
if {not ([catch {eval $cipher_cmd} result]) && $result ne “none”}{
Client did use a cipher
if {$static::CatchSSLErrorsDebug == 1} { log local0.info “SSL Connection initiated… Verifying client certificate.” }
catch {eval $count_cmd} count_result
if {$static::CatchSSLErrorsDebug == 1} { log local0.info “SSL::cert returned the following output… ‘$count_result’” }
if {$count_result ne “”} {
if {$static::CatchSSLErrorsDebug == 1} { log local0.info “Client cert presented. Verifying…” }
catch {eval $verify_cmd} verify_result
if { $verify_result == 0 } {
Client Cert present and verified successfully.
if {$static::CatchSSLErrorsDebug == 1} { log local0.info “SSL::Verify_result was OK… ‘$verify_result’ Continuing…” }
return
Client cert verification error.
if {$static::CatchSSLErrorsDebug == 1} { log local0.info “SSL::Verify_result was NOT OK… ‘$verify_result’” }
Get failure reason
catch {eval $failure_cmd $verify_result } failure_result
if {$static::CatchSSLErrorsDebug == 1} { log local0.info “X509::verify_cert_error_string value is… ‘$failure_result’” }
event disable
return
if {$static::CatchSSLErrorsDebug == 1} { log local0.info “No Client cert presented. Returning error page…” }
Return failure page. No Client cert presented…
set failure_result “No client certificate present”
event disable
return
Client did not use a cipher
if {$static::CatchSSLErrorsDebug == 1} { log local0.info “Non-SSL Connection initiated… Continuing…” }
return
Sorry, $failure_result is calculated at runtime, so your solution of calling subst at runtime is perfect. You should be able to get the ifile contents in RULE_INIT using ‘set static::error_page [ifile get error_page_html]’ and then call subt against that with HTTP::respond:
HTTP::respond 403 content [subst $static::error_page] “Content-Type” “text/html” “Connection” “Close”
The advantage to doing this is that you’re only loading the ifile once at load time instead of every request. I assume this is more efficient, but haven’t tested it before. If you wanted to, you could enable timing on the iRule with the two different iRule versions and make a batch of requests to compare.
http://devcentral.f5.com/wiki/iRules.timing.ashx
Aaron
Aaron
Cheers for the tips… Will give it a go and see which one comes out on top :slight_smile:
Cheers
Gavin
If you do, could you post back with what you find for future reference?
Thanks, Aaron
Ok, results are in…
With the ‘get ifile’ command on each request:
show CatchSSLErrors
Ltm::Rule Event: CatchSSLErrors:HTTP_REQUEST
Priority 10
Executions
Total 200
Failures 0
Aborts 0
CPU Cycles on Executing
Average 664.4K
Maximum 1.6M
Minimum 0
Ltm::Rule Event: CatchSSLErrors:RULE_INIT
Priority 500
Executions
Total 1
Failures 0
Aborts 0
Average 0
Maximum 0
Minimum 0
With the ‘get ifile’ commands in the RULE_INIT block:
show CatchSSLErrors
Priority 10
Executions
Total 200
Failures 0
Aborts 0
Average 639.6K
Maximum 1.0M
Minimum 0
Priority 500
Executions
Total 1
Failures 0
Aborts 0
Average 0
Maximum 0
Minimum 0
This was with a request size of 200 attempts…
So there’s definitely a difference between the 2..
Is it likely to make a big difference? As I’m not that familiar with what’s good and what’s bad when it comes to iRules and timings…
Cheers
Gav
Thanks for testing. 200 requests should be enough to get an idea of the average CPU cycles each version uses. To compare, the ifile get in RULE_INIT version is ~4% more efficient:
664 - 639 / 639= 3.9%
Not as much as I expected, but still good enough in my mind to justify doing the ifile get once in RULE_INIT. I guess it’s a sign that doing the ifile get is pretty efficient.
Aaron
Indeed…
Probably also worth noting that this was run against a v11 Virtual install…
I also upped the thread count to get 2k hits, and it showed a very similar percentage difference… So appears to scale linearly…
I’ll run the same tests against a physical device when I get a chance to see if that gives a bigger margin…
Cheers
Gavin
FYI, I’ve also added a slightly modified version of this rule to Codeshare…
Just removed the Logo lines which are specific to our implementation…
The link is: http://devcentral.f5.com/wiki/iRules.Catch-SSL-Errors-and-return-a-friendly-page.ashx
Cheers again.
Gav
That looks great. Thanks for adding it to the codeshare.
One small suggestion, I don’t think you need the event disable or return commands as you have everything wrapped in if/elseif/else’s.
Aaron
Aaron
I added them in as I was getting ‘multiple redirect/respond invocation’ errors logged from other rules that I’ve got set-up…
So just did it to ensure that no other processing would take place…
Am happy to make a change if there’s a better way though…
Gav
Aaron
Gav
How about trying TCP::close after HTTP::respond without event disable or return? Do you still see the multiple redirects runtime error?
HTTP::respond…
TCP::close
Aaron
