Catch double words in URL requests
Hi together,
i have the following question:
Some sample URL requests like
1. http://www.somehost.com/index.html?timestamp=1214461652028255801?bla=12
2. http://www.somehost.com/index.html?timestamp=1214461652028255812?bla=12
3. http://www.somehost.com/index.html?timestamp=1214461652028255903?bla=12
4. http://www.somehost.com/index.html?timestamp=1214461652028255803?bla=12
5. http://www.somehost.com/index.html?timestamp=1214461652028255903?bla=12
6. http://www.somehost.com/index.html?timestamp=1214461652028256003?bla=12
7. http://www.somehost.com/index.html?timestamp=1214461652028255803?bla=12
8. http://www.somehost.com/index.html?timestamp=…?bla=12
Now I want catch every request that use the timestamp=xxx more then one times during the last 1000 requests and redirect them to a other page.
In this example, 4 and 7 are double, the rest are OK.
Thanks for help
bjoern
Do you really need it to be the last 1000 requests, or would it be OK for it to be “more than once during the last N seconds”?
yes, that should be also OK
In that case, you should just be able to parse the timestamp value out of the URI and check it against the session table. If it isn’t there, then save it in the session table with your N second timeout. If it is there, then that timestamp was seen in the last N seconds, and you can take whatever action you want. Make sense?
