Is it possible if we can capture all the source IP that are hitting our VIPs.
HI,
Yes it is possible to capture the soruce Ip addresses hitting the vip using irule, in case if you want to see it on the backend server (running http), you can try enabling XFF (X-Forwarded-For) option to see the cient IP in headers at server side (webserver.)
-M@rcus
Yeah, You can capture client IP address via iRule or X-Forwarded-For.
For more information go through below F5 Article.
Option 1: X-Forwarded-For HTTP header K4816
Option 2: iRule
log local0. "clientIP:[IP::client_addr] accessed [HTTP::host][HTTP::uri]"
Hope your issue will be solved..
We are looking for a way to look at the historical connections for a particular vip, Is it something we can achieve through enterprise manager (EM).
Have not see any such feature for historical connections using EM, but BigIP F5 LTM - Application Visibility and Reporting module can be helpfull.
