Capturing Application traffic without using AVR
hi,
Can we capture application traffic on LTM without using AVR to investigate latency issues?
You can use tcpdump through CLI or you can define a clone pool to your Virtual Server.
Then, you will need some extra software to calculate latencies.
Bye
Yann
Bye
Yann
Hi Yann,
Could you please clarify on the Virtual Server Clone pools?
Also can you share what extra softwares will be required?
Hi Yann,
Hi Allwin,
There is an article describing this feature.
You can then use third party software like Splunk, Riverbed, Dynatrace, …
Hi Allwin,
