Hello,
I try to used captive portal detection with BigIP client, It works well, excepts on wifi with proxy.
Do you know if this fox can correct this problem ?
425377 BIG-IP Edge Client now correctly detects captive portal if requests go through tunnel and then through BIG-IP-defined proxy server.
Thanks for your help !
I’ve find this error logs on my BigIP client:
Standalone,3024,5608,Server is: sslvpn.mycompany.com (SSLVPN Access) User status is: Downloading server settings...
APPCTRL,3024,5608,Loading configuration. URL: "https://sslvpn.mycompany.com/pre/config.php?version=2.0"
Standalone,3024,5608,Internet connection state: 18
APPCTRL,3024,1244,INTERNET_STATUS_DETECTING_PROXY - WinIet notifies the client application that a proxy has been detected.
APPCTRL,3024,1244,INTERNET_STATUS_COOKIE_SENT - Indicates the number of cookies that were either sent or suppressed, when a request is sent (2).
APPCTRL,3024,1244,INTERNET_STATUS_CONNECTING_TO_SERVER - Connecting to the socket address (X.X.X.X). (=IP of sslvpn.mycompany.com)
APPCTRL,3024,1244,INTERNET_STATUS_CONNECTED_TO_SERVER - Successfully connected to the socket address (X.X.X.X).
APPCTRL,3024,1244,INTERNET_STATUS_SENDING_REQUEST - Sending the information request to the server.
APPCTRL,3024,1244,INTERNET_STATUS_REQUEST_SENT - Successfully sent the information request to the server. 437 byte(s) sent.
APPCTRL,3024,1244,INTERNET_STATUS_RECEIVING_RESPONSE - Waiting for the server to respond to a request.
APPCTRL,3024,1244,INTERNET_STATUS_RESPONSE_RECEIVED - Successfully received a response from the server. 559 byte(s) received.
APPCTRL,3024,1244,INTERNET_STATUS_CLOSING_CONNECTION - Closing the connection to the server.
APPCTRL,3024,1244,INTERNET_STATUS_CONNECTION_CLOSED - Successfully closed the connection to the server.
APPCTRL,3024,1244,INTERNET_STATUS_REDIRECT - An HTTP request is about to automatically redirect the request: "http://freewlan.wireless.com/sms_registration?requested_url=https%3A%2F%2Fsslvpn.mycompany.com%2Fpre%2Fconfig.php%3Fversion%3D2.0"
APPCTRL,3024,1244,INTERNET_STATUS_REQUEST_SENT - Successfully sent the information request to the server. 281 byte(s) sent.
APPCTRL,3024,1244,INTERNET_STATUS_RESPONSE_RECEIVED - Successfully received a response from the server. 1024 byte(s) received.
Standalone,3024,2164,Network event occured
Standalone,3024,2164,Network event occured while waiting for connection to settle
Standalone,3024,2164,[NLA] Location test started
Standalone,3024,2164,[NLA] Automatic connection mode disabled - no need to test location
Standalone,3024,2164,[NLA] Fire network event. Location: LOCAL_NETWORK_UNKNOWN
Standalone,3024,5608,DetectCaptivePortalInDialer returned ERROR_MOD_NOT_FOUND; Use default portel detection method.
Standalone,3024,5608,Trying to download a file over HTTP(URL), http://www.f5.com/apps/all/avail.txt
Standalone,3024,7456,HttpSendRequest failed with HTTP 303.
Standalone,3024,5608,Connection failed (URL: http://www.f5.com/apps/all/avail.txt)
