I am running 9.4.3 HF3. I use this iRule in a training class so I’m trying to get it to work even though you can do this in the HTTP profile now. Basically the cookie is encrypted but not decrypted. I’m using the iRule from DevCentral:
when RULE_INIT {
The appliation cookie to encrypt/decrypt
set ::app_cookie “user”
The encryption passphrase. This can be any string.
set ::cookie_passphrase “passphrase123”
Log debug messages to /var/log/ltm? 1=yes, 0=no.
set ::cookie_encrypt_debug 1
Check if the cookie we want to decrypt exists with a value in the request
if {[string length [HTTP::cookie value $::app_cookie]]}{
Decrypt the cookie value and save the output to the variable $decrypted_value
set decrypted_value [HTTP::cookie decrypt $::app_cookie $::cookie_passphrase]
if {$::cookie_encrypt_debug}{log local0. “\decrypted_value: $decrypted_value”}
when HTTP_RESPONSE {
Check if cookie we want to encrypt exists with a value in the response
Encrypt the cookie value and save the output to the variable $encrypted_value
set encrypted_value [HTTP::cookie encrypt $::app_cookie $::cookie_passphrase]
if {$::cookie_encrypt_debug}{log local0. “\encrypted_value: $encrypted_value”}
Here are the log entries:
Feb 27 14:37:24 tmm tmm[1656]: Rule Student0_CookieEncryption : encrypted_value: TjRpIjzo7cmDgGUcE0LPqV5ujdsYUjwF8KdzF46zTzwO5CM0NWHM0FmN
Feb 27 14:38:37 tmm tmm[1656]: Rule Student0_CookieEncryption : decrypted_value:
Note how the cookie decrypt returns no value. The cookie is not decrypted in this case and is sent encrypted to the back-end server. Any idea what is wrong?
