Can't create Node in iApp using variables
Hi! I’m trying to create a Node using iApp with the following simple Implementation:
package require iapp 1.0.0
iapp::template start
set addr 1.1.1.1
iapp::conf create ltm node test { address $addr }
iapp::template stop
But when I create a new Application using this iApp, I receive the following error:
script did not successfully complete: (“$addr” invalid IP address while executing "tmsh::create [string range $args 7 end] " (“create” arm line 1) invoked from within “switch -exact -- [string range $args 0 5] { create { tmsh::create [string range $args 7 end] } modify { tmsh::modify [string r…” (procedure “iapp::conf” line 14) invoked from within “iapp::conf create ltm node test { address $addr }” line:6)
In the other hand, if I use the following Implementation (using an IP, not a variable), it works:
iapp::conf create ltm node test { address 1.1.1.1 }
iapp::template stop
Is there any cast I must do?
Thanks!
Hi Franco,
You need to escape those curly braces, like this:
set addr 1.1.1.1
iapp::conf create ltm node test \{ address $addr \}
iapp::template stop
Great, you are right, thanks!
