Hi
I use platform c62a and BIG-IP v. 9.1.2 and that have problem with gui so I try to save config via command line
when I prompt “b config save (name.ucs)”
It’s said
Saving active configuration
Creating UCS for config save request
mv: cannot create regular file “/var/local/ucs/name.ucs” : No space left on device >>> *(not true)
/var/local/ucs/name.ucs : Error renaming package
Error creating package
BIGpipe: 01110001:3: Error running configsync
Is this bug or known issue? I just want to know how this happen and how to workaround.
although I will upgrade in to v. 10.2.4 to fix many issue
ps. It’s also have "Error executing shell command. " error in GUI
