Hi After updating cert in F5_A, if the config does not work, can we use Sync to overwrite from F5_B(cert have not been updated) to this F5_A? Thank you
Yes, you can Sync device from F5_B to F5_A. Select option Sync to device peer(1st Option)
As Samir has said - 100% possible.
Also as good practice, if your security policy allows - take a .ucs backup with Certs included before editing ![]()
You might also want to look at - instead of overwriting certs, creating a new one… And deleting the old one after successful testing.
