Is there a way to do via policy to block url but when the method is POST ? or doing via irule is the only way ?
You can do It using hamish method (LTM policy).
You can also do it using Irule:
if {[string tolower [HTTP::method]] contains "post"}{
log local0. "Forbidden HTTP method ([HTTP::method]) attempted by [IP::client_addr]"
reject
With Irule you can log URI, Source IP …
Regards,
