We introduce i2600 this time.
I want to be transparent in multiple VLANs on LTM i2600.
Example.
[VLAN10, 20] → BIG-IP VS → [VLAN10, 20]
Can we use Virtual Wire on BIG-IP LTM i2600?
If we can not use it, is there a substitute?
Example.
Hello.
These are the supported platforms →
I think there is some mistake regarding i12600, it should say i2600 instead (because this model doesn’t appear on the product datasheet)
I also pass you an implementation guide
KR,
Dario.
ummm, I can not find “i2600” on page 9 of its URL.…
Although there is “i12600”.
I did some correction on my previous comment.
Sorry for the confusion, but it seems that i12600 is a new product not released yet
Your device has this hardware code
i2600 / i2800 - C117
And D117 is not still on the list
Final conclusion:
It’s not supported.
KR,
Dario.
BTW, I think you have been asking for a similar question in another topic…
As far as I know your unique alternative is VLAN Group transparent (to keep your source MAC address).
You have a perfect explanation about behaviour and implementation here
And our colleague SWJO has already given you some guidelines
Hope this helps.
KR,
Dario.
