I am trying to see statistics type from page
that links to
But I get request timed out all the time.
I am trying to see, what statistics type I can get from BIG-IP using iControl.
I don’t have option for REST as I am using version lesser than 11.5.
that links to
I was trying to get the statistics for the following type:
STATISTIC_SSL_PROTOCOL_SSLV2
STATISTIC_SSL_PROTOCOL_SSLV3
Is that ever implemented because I do not get those type back.
code:
def get_virtual_statistics(obj, virtual):
try:
statistics = obj.LocalLB.VirtualServer.get_statistics([virtual])
return statistics
except Exception, e:
print e
I only see the following type returned:
STATISTIC_MINIMUM_CONNECTION_DURATION
STATISTIC_MEAN_CONNECTION_DURATION
STATISTIC_MAXIMUM_CONNECTION_DURATION
STATISTIC_NO_NODE_ERRORS
STATISTIC_CLIENT_SIDE_BYTES_IN
STATISTIC_CLIENT_SIDE_BYTES_OUT
STATISTIC_CLIENT_SIDE_PACKETS_IN
STATISTIC_CLIENT_SIDE_PACKETS_OUT
STATISTIC_CLIENT_SIDE_CURRENT_CONNECTIONS
STATISTIC_CLIENT_SIDE_MAXIMUM_CONNECTIONS
STATISTIC_CLIENT_SIDE_TOTAL_CONNECTIONS
STATISTIC_PVA_CLIENT_SIDE_BYTES_IN
STATISTIC_PVA_CLIENT_SIDE_BYTES_OUT
STATISTIC_PVA_CLIENT_SIDE_PACKETS_IN
STATISTIC_PVA_CLIENT_SIDE_PACKETS_OUT
STATISTIC_PVA_CLIENT_SIDE_CURRENT_CONNECTIONS
STATISTIC_PVA_CLIENT_SIDE_MAXIMUM_CONNECTIONS
STATISTIC_PVA_CLIENT_SIDE_TOTAL_CONNECTIONS
STATISTIC_EPHEMERAL_BYTES_IN
STATISTIC_EPHEMERAL_BYTES_OUT
STATISTIC_EPHEMERAL_PACKETS_IN
STATISTIC_EPHEMERAL_PACKETS_OUT
STATISTIC_EPHEMERAL_CURRENT_CONNECTIONS
STATISTIC_EPHEMERAL_MAXIMUM_CONNECTIONS
STATISTIC_EPHEMERAL_TOTAL_CONNECTIONS
STATISTIC_VIRTUAL_SERVER_SYNCOOKIE_HW_INSTANCES
STATISTIC_VIRTUAL_SERVER_SYNCOOKIE_SW_INSTANCES
STATISTIC_VIRTUAL_SERVER_SYNCOOKIE_CACHE_USAGE
STATISTIC_VIRTUAL_SERVER_SYNCOOKIE_CACHE_OVERFLOWS
STATISTIC_VIRTUAL_SERVER_SYNCOOKIE_SW_TOTAL
STATISTIC_VIRTUAL_SERVER_SYNCOOKIE_SW_ACCEPTS
STATISTIC_VIRTUAL_SERVER_SYNCOOKIE_SW_REJECTS
STATISTIC_VIRTUAL_SERVER_SYNCOOKIE_HW_TOTAL
STATISTIC_VIRTUAL_SERVER_SYNCOOKIE_HW_ACCEPTS
STATISTIC_TOTAL_REQUESTS
STATISTIC_TOTAL_PVA_ASSISTED_CONNECTIONS
STATISTIC_CURRENT_PVA_ASSISTED_CONNECTIONS
STATISTIC_VIRTUAL_SERVER_TOTAL_CPU_CYCLES
STATISTIC_VIRTUAL_SERVER_FIVE_SEC_AVG_CPU_USAGE
STATISTIC_VIRTUAL_SERVER_ONE_MIN_AVG_CPU_USAGE
STATISTIC_VIRTUAL_SERVER_FIVE_MIN_AVG_CPU_USAGE
STATISTIC_ACL_NO_MATCH
That topic was just updated and was greatly expanded in the latest release so it could be taxing our wiki system processing it. I’ll look at it and get it fixed by tomorrow. Sorry for the inconvenience…
The topic page for Common.StatisticType should be fixed now, again sorry for the inconvenience. Keep in mind that this is just an all-inclusive list of all statistic types across all interfaces on the BIG-IP. There are over 1500 of them so the content is broken across 15 pages. Look at the bottom for an index link list that you can use to navigate across all of them.
As for your original question, that topic does not list which methods return each statistic. It just lists them out with the description for that statistic type. We currently do not have a detailed list of which statistics are returned for each method. You will have to query the interface and see which stats are returned in real time. I’ll see what I can do to get those mappings but that will likely be a pretty significant effort. I’ll keep you posted if/when I have that solution.
Hope this helps…
-Joe
Thanks JOE. Indeed it was an effort, finally I found the SSL statistics in
LocalLB.ProfileClientSSL.get_statistics_by_virtual
I have written a script to get SSL traffic statistics. Hope this helps if they are considering to upgrade to 11.5.x or higher or find the clientssl profile being used in the virtual server.
def get_virtuals(obj):
try:
return obj.LocalLB.VirtualServer.get_list()
print e
def get_virtual_profiles(obj):
try:
virtual = get_virtuals(obj)
profiles = obj.LocalLB.VirtualServer.get_profile(virtual)
return virtual, profiles
print e
def get_virtual_client_ssl_statistics(obj, profile,virtual):
try:
statistics = obj.LocalLB.ProfileClientSSL.get_statistics_by_virtual([profile], [[virtual]])
return statistics
print e
def return_true_types(ssl_type):
allowed_types = ["STATISTIC_SSL_PROTOCOL_SSLV2", "STATISTIC_SSL_PROTOCOL_SSLV3", "STATISTIC_SSL_PROTOCOL_TLSV1", "STATISTIC_SSL_PROTOCOL_TLSV1_1", "STATISTIC_SSL_PROTOCOL_TLSV1_2"]
if ssl_type in allowed_types:
return True
if __name__ == "__main__":
import bigsuds
import getpass
import sys
import os
if len(sys.argv)< 3:
print ("Usage %s ip_address username" % sys.argv[0])
sys.exit()
a = sys.argv[1:]
print ("\nHey %s, please enter your password below.\n" %a[1])
upass = getpass.getpass()
try:
b = bigsuds.BIGIP(
hostname = a[0],
username = a[1],
password = upass,
print (e)
Files
file_name = a[0] +".csv"
path_to_folder= os.getcwd()
path_to_file = path_to_folder +"/"+ file_name
if (os.path.isdir(path_to_folder)):
if(os.path.exists(path_to_file)):
try:
os.remove(path_to_file)
data_file = open(path_to_file, 'a')
print (e)
else:
virtual, profiles = get_virtual_profiles(b)
combined = zip(virtual, profiles)
for x in combined:
for y in x[1]:
if y["profile_type"] == "PROFILE_TYPE_CLIENT_SSL":
clientssl_profile = y["profile_name"]
print x[0] + " " + clientssl_profile
data_file.write(x[0] + ",")
data_file.write(clientssl_profile + ",")
print "============================="
statistics = get_virtual_client_ssl_statistics(b, clientssl_profile, x[0])
for iter in statistics["statistics"][0][0]:
if return_true_types(iter["type"]):
data_file.write(str(iter["value"]["high"]) + "," + str(iter["value"]["low"]) + ",")
print iter["type"] + " " + str(iter["value"]["high"]) + " " + str(iter["value"]["low"])
data_file.write("\n")
