Hi everyone,
I have a VS "performance (Layer 4)"type, without destination address, which captures TCP traffic by source address, in all ports, and directs it to a POOL. This is working correctly.
This is the configuration of VS
ltm virtual inv_wifi_1 {
destination 0.0.0.0:any
fallback-persistence dest_addr
ip-protocol tcp
mask any
persist {
source_addr {
default yes
pool wifi_Any
profiles {
fastL4_NO_syncookie_protection { }
rules {
wifi
source 10.0.4.0/24
translate-address disabled
translate-port disabled
vs-index 2
Now I want the traffic that is being captured and balanced towards the pool to be forwarded, considering the destination IP. I created the following iRule but it is not working. I need some help creating an iRule to make all trafic redirect based on the dest IP address.
ltm data-group internal net_CPD_allow {
records {
10.0.5.0/24 { }
type ip
My irule is the following:
if { ([matchclass [IP::remote_addr] equals net_CPD_allow]) }{
log ltm.
log local0. " IP [IP::client_addr] cpd --> 10.5.0.0/24"
10.5.0.0/24 routing
forward
Internet.
pool "wifi_Any"
The irule does nothing. It is developed correctly, since no errors are observed in the compilation.
Can somebody help me
