SO i have a strange problem with SSL handshake time out exceeded with a particular client. I was thinking about rather than increasing time out in SSL profile can i write an irule to modify the SSL connection behavior from that client? Is it even possible?
Yes this is possible. But instead of trying to change 1 parameter for a specific source-IP, it is easier to do it this way
Define a new SSL profile with customized parameters lets say clientssl_slowclients.
Keep the virtual with the existing SSL profile.
In the irule, assign this SSL profile once you determine that it is a slow client.
when CLIENT_ACCEPTED { if { [client_addr] … ur checks } { SSL::profile clientssl_slowclients } }
