Hi expert,
Recently, I have a need to apply WAF policy to a VoIP service, and I was told to use SIP protocol, but I went to Virtual Server and found that I can’t apply http profile.
Does it mean I can’t apply WAF policy?
Hello,
WAF Policy is just for Web applications not SIP, FTP, SMTP …etc.
All you can do for SIP:
- you can use SIP DOS Vectors if you have AFM or DHD “DDoS Hybrid Defender” modules.
- SIP Inspection profile and you need to have an active subscription to configure and use inspection profiles, look at the following snapshot to know more about inspection:
that’s all for SIP.
Good luck ![]()
