Can not import iApps
Hi there, I can’t import iApps to BIG-IP, can you help me?
Here is the info:
  • iapps-1.0.0.157.0 (MD5 OK)
  • BIG-IP 11.5.1 HF3, Virtual Edition, LTM+ASM, (Installation OK)
When i click upload on the GUI, this error showed up: (!)Loading configuration… /tmp/upload_template.tmpl Syntax Error:(/tmp/upload_template.tmpl at line: 1) “PK” unexpected argument
error on /var/log/ltm: err tmsh[12719]: 01420006:3: “PK” unexpected argument
I try on my second BIG-IP (with same version different module), but resulting the same.
Any idea? Thanks before,
Peter
“PK” is the first characters in a ZIP header. It’s probably zipped. Try renaming the file to .zip and decompressing it, then do the upload.
I believe lthompson has the right idea.
iApps come as a zipped package. Unzip the package, then select and import the iApps you are looking for onto your LTM.
A list of steps is here: DevCentral - An F5 Technical Community
Thank you lthompson, it is solved now.
Is that possible to import several template at once. For example using scp. Instead of import exchange, import citrix etc tq
No.
