Can not create vlan in F5
Please see below picture. The vlan cannot be created in F5. What is wrong? Anyone can give me suggestion? Thank you
Which plateform do you run ? vCMP guest ? Virtual Edition ?
Do you get this warning during the wizard ?
Thank you so much for your reply. I am new to F5, My F5 is not virtual edition. It is real device. The F5 is old one and i am not running wizard. I am just trying to add a new vlan, and then I got that error message. Please let me know how to answer your other question. Thank you again
Can you share the outputs of your interfaces ?
( list net interface / show net interface )
Whats going to be the purpose of this VLAN ?
I got below info after I used that command. Do you think if my F5 is not in normal mode? Thank you [admin@LTM-6:Standby:Awaiting Initial Sync] ~ list net interface -bash: list: command not found [admin@LTM-6:Standby:Awaiting Initial Sync] ~ show net interface -bash: show: command not found
I got the below output after using that commands. I do not know whether it is not in the normal mode? The vlan is for routing purpose. Thank you
[admin@LAB-LTM-6:Standby:Awaiting Initial Sync] ~ list net interface
[admin@LAB-LTM-6:Standby:Awaiting Initial Sync] ~ show net interface
You’d need to run the commands in TMSH. Enter tmsh at bash prompt.
Sorry for the delay due to other project
Now I still cannot create vlan as before. the below is output of command “show net interface”
Thank you
perhaps im missing something but nowhere i see the command you try and fails, please (re)post that, you also just execute one of the commands IainThomson85 is asking about.
Thank you for your response. I reposted the output for the command : show net interface
