can I using adobe flash player after 12/31 ?
Hi guys I need your help
as you can know 11.x version need adobe flash player for watch dash board
network environment like below
f5 and pc can’t access external internet
so, can I using adobe flash player after 12/31 ?
pc, f5 can’t get any update from external internet
browser version is
exploler 11
version : 11.836.18362.0
update version : 11.0.190(KB4556798)
Please help me !
I believe, There will not be any issue in terms of flash player in 11.6.x event after 12/31.
BIG-IP 14.x and above you don’t need flash player.
F5’s recommendation for dealing with the need for Adobe Flash Player in BIG-IP versions prior to 14.0 is documented here - K40913294: Adobe Flash Player Version for Dashboard Utility - and here - Bug ID 534474: Dependency on Adobe Flash removed from the BIG IP Dashboard.
With respect to Microsoft’s browser support for Flash Player, I found this article on their blog: Update on Adobe Flash Player End of Support. Although I cannot and do not speak on Microsoft’s behalf, I think you will find the guidance you are looking for in that article.
