What if you use LB::down with no arguments? I believe that this will set the status of just the pool member to down--not the node--and might have the effect you’re looking for. If that doesn’t work, you might try explicitly setting the pool member down.
I think you can get the selected pool member info using LB::server (Click here) in HTTP_RESPONSE. If you get a runtime TCL error from trying this, you could save it in the LB_SELECTED event and then reference it in HTTP_RESPONSE. You might first try hardcoding the pool info with LB::down to see if the effect is what you’re looking for.
