Can I display ssl handshake fail reason using irule?
Hi guys I need your help
I have list of ssl handshake failure alert but I don’t know how to define alert using irule
ex) 40 is The sender was unable to negotiate an acceptable set of security parameters given the options available.
please let me know if you know way
thank you
No - you need to use SSL debug logging (for BigIP versions prior to 12.0.0)
K09322055:  The BIG-IP system now logs debug SSL errors through standard logging
K15475:  Troubleshooting SSL/TLS renegotiation
thank you for share your knwoledge
So, can I display other log when  " Connection error: hud_ssl_handler:1289: codec alert (20) " log display ? like " display codec alert (20) is occur cause Using Diffie-Hellman (DH) ciphers "
