Can I create a monitor for port 514?
Can I create a monitor to query my syslog servers to make sure they are listening on port 514? For those of you who have a logging pool set up, how are you monitoring those servers?
By default, a TCP or UDP monitor will probe the pool members on their specified port. The exception would be if the pool members are defined on all ports (:0), so the monitor must specify an Alias Port value which will be used to probe the members.
Yes you can configure the parent monitor to udp/tcp and configure the alias port to 514.It should work
You can very well create a TCP monitor to that Port.
Alias port is what you are looking for
Awesome, thank you all for your answers.
