Can F5 compete with Fat Pipe-Warps products
The customer has 5 Broadband connections and would like to Loads balance across 5 WAN links. Can this be done?
Hello there,
This forum is for addressing iRule questions. I think you might do better to contact F5 sales for product information:
Click here
Aaron
Hi Aaron,
thanks have also done that, this is the first time using DevCentral thought i would give it a try to see if i could get a quicker response as it stated this is a forum. I presume this is for iRules alone?
You are correct:
The F5 DevCentral Forum is provided to assist with iControl, iRules and FirePass customization development. It is not official F5 technical support nor is it a forum for standard product configuration and administration issues.
Sales should be able to provide you with a complete recommendation for how BIG-IP can support multiple links.
If you want get technical documentation and/or white papers, you can check out AskF5.com (free sign-up required) and www.f5.com.
Aaron
Cheers
