Check an http request for a specific cookie. If the cookie isn’t there then respond with an http redirect. I can do this fairly easily using iRules.
Otherwise (if the cookie is there) route the traffic onwards to a pool of transparent proxy servers which can access the web (so a default router pool in effect). I have failed miserably to get this second part to work.
I’d suggest creating a 0.0.0.0:80 VIP (wildcard vip on a specific port) with an HTTP profile. You should then be able to use a rule like this to check for the cookie:
Check if the cookie exists
if {[HTTP::cookie exists "my_cookie"]}{
Use the proxy pool
pool proxy_pool
Redirect the client
HTTP::redirect "http://redirected.example.com"
You might want to try adding some kind of validation of the cookie value as the above example could be bypassed by a client manually inserting a cookie with the name.
That makes sense. What does the proxy_pool include exactly (I think this is where our problem lies). Does it include router or proxy IP addresses, or something else entirely.
If the proxy servers can be routed to, you could add them to a pool and specify that in the rule. If you want to forward the requests with the cookie according to LTM’s routing table, replace ‘pool proxy_pool’ with ‘forward’.
