calculation for monitors
Hello,
i want monitor servers with download url
for example GET /logon/index.html
i want calculate index.html time value and if this value between x and y or gretar y set down to server if not set it up
how can i use like this monitor or another ways?
regars
Zafer Berber
I’m a little fuzzy on the exact details of your question, but it sounds like you want to set a monitor with a timeout, and if that timeout is reached, mark the node down.
If that’s indeed what you’re looking for then all you need to do is set up an HTTP monitor. In the Local Traffic → Monitors section of the GUI you can create a new HTTP monitor and one of the fields is the Timeout value. By adjusting this to the desired interval you’ll be able to control how long the BIG-IP waits before considering the connection timed out, and therefore the monitor failed.
HTH,
Colin
