Hello I am currently writing a logging event to capture a message but I am finding that by enabling the TCP::collect event the processing is being slowed down by as much as 2 seconds. As the messages are variable length we have a two byte prefix in front of the message that gives the payload length minus the two byte header e.g. <0x00 0x04> <\x02 12 \x03> I want to try capturing the prefix and calculate the message length from this and then apply a check to see once the message length is reached call TCP::release to try and speed this process up. I am struggling to calculate the two byte header and hoping someone may be able to assist me. I have been dabbling with Binary Scan but cannot get the correct result.
Thank you James
Can you post your full iRule so we can understand exactly what you’re asking? thanks
James
I would start by collecting only 2 bytes. Convert those from hex to decimal and then collect that number of bytes before you release.
when CLIENT_ACCEPTED {
TCP::collect 2
set header_collected "false"
when CLIENT_DATA {
if { not ($header_collected) } {
Comment out one of the two binary scan lines below.
use this form if lower order byte is last (big endian order)
binary scan [TCP::payload] S message_length
use this form if lower order byte is first (little endian order)
binary scan [TCP::payload] s message_length
if { $message_length > 0 } {
set header_collected "true"
log local0. "Collecting message with length $message_length"
TCP::collect $message_length
if we are here the actual message is collected.
set actual_message_text [TCP::payload]
TCP::release
Feel free to post what you have and we take a look.
Examples of binary scan:
% binary scan \x02\x00 s var1
1
% puts $var1
2
% binary scan \x00\x03 S var1
1
% puts $var1
3
HTH.
Thank you for this John. I am going to look at this further and will post back how I get on.
John
I had to enhance your code slightly as the payload messages are quite small and therefore client_data event was not getting triggered again as the LTM has already buffered the rest of the data. I have therefore now added a check to see if we already have the data or not and if we do TCP::release. I cannot see a more affiant way of doing this, what do you think?
TCP::collect 2
when CLIENT_DATA {
as the message length collected does not include itself add 2 more onto the result
set message_length [expr { $message_length + 2 }]
collect data with the required length
check if we already have the required data in the buffer if so
capture the payload in vars and release it
if {[TCP::payload length] == $message_length } {
set vars with payload info for HSL logging later
set my_req_msg_payload [TCP::payload]
set my_req_msg_length [TCP::payload length]
release the data already collected
TCP::release
TCP::release
Please see enhancement to the code here below.
Good catch.
Your modification look great. Only a couple suggestions:
1) don’t add the 2 to the message_length variable because it is used for the TCP::collect later, instead add it within the comparison operation.
2) Perform the second the TCP::collect in the else statement so that it can be avoided if not needed.
Here is what it would look like:
TCP::collect 2
when CLIENT_DATA {
if {[TCP::payload length] == [expr { $message_length + 2 }] } {
TCP::release
TCP::release
if you are on 11.4 or above, here is a slight variation in order to demonstrate iRule procedures “proc”.
proc save_n_let_it_go args {
the args variable is ignored here
release the data already collected to be forwarded to destination.
TCP::release
TCP::collect 2
when CLIENT_DATA {
call save_n_let_it_go
John, I have just tried your enhancement but this does not work for me until our software sends the request again then it works. I have reverted to the previous version of code that I included. I like the code on 11.4 not aware of the procedures function however I am on 11.3 at the moment but will keep that in mind for the future.
Thanks for the feedback. Good luck.
