Hi. I would like to know if Cacti will provide more information about our BigIPs over Solarwinds Orion. Today we monitor the BigIPs with Orion but we don’t get any useful stats besides CPU Utilization. What we really need is interface utilization, http/https responses/requests and a few others. We do monitor the switch interfaces that the BigIPs are connected to but that doesn’t help all that much.
I’d use a web analytics tool to comb the web server logs for this. You might be able to use a statistics profile for this, but I think it would require a sorted array to get your top X IP hits into the stats profile. Even at that, I’m not sure if the stats profile fields are available in the mibs. Anyone?
Other option is to log client IP addresses with an iRule, there are plenty of examples on the forum for this.
I’d like to use Orion UDP also, but, I can’t seem to find the right OID to monitor. If I go into the Performance section on an LTM, I see they are using RRDTOOL which we use also, but, I can’t for the life of me figure out what OID’s are being monitored?
