I have not tried this, but if you have repeatable results just from a snmpwalk, then I’d get a case open. If found to be a bug, can you post the CR back here?
having the same problem with LTM 8900, v10.2 for the pool connection snmp queries. the snmpwalk f5_bigip_pool.xml for the working 6400 show many values. the snmpwalk f5_bigip_pool.xml for the not working 8900 shows: No Such Object available on this agent at this OID. So I think there must be a difference in the OIDs between both machine types.
So I’ve done 2 snmpwalk on different LTM machine types but same v10.2, first the working LTM 6400:
[a2590172@cdcacp01 ~]$ snmpwalk -v2c -c public loadbal6400 .1.3.6.1.4.1.3375.2.2.5.2.3.1.1
[a2590172@cdcacp01 ~]$ snmpwalk -v2c -c public loadbal8900 .1.3.6.1.4.1.3375.2.2.5.2.3.1.1
SNMPv2-SMI::enterprises.3375.2.2.5.2.3.1.1 = No Such Object available on this agent at this OID
This means that there must be a difference between the pool MIB’s. I would like to know if I have to find a workaround for this and build new cacti definitions, or I can wait for a patch.
