We are setting up our two 5250v’s. We want to use 10Gb link aggregation to the network and also active/standby HA.
I read on a whitepaper that you should use both direct and network failover methods. I was planning on connecting them from failover-to-failover, and then connecting them layer 2 together through our network using port 1.4. I know the failover port requires a crossover.
Does this sound okay?
My VAR was saying to directly connect them with two different links, though; so i’m not sure whether that’s the better method.
For the front-end trunks i’m going to trunk all the client/server-side vlans i need and break them out in the bigip w/ vlans. We’re planning on using vcmps/route-domains/ and partitions for the different prod, beta, and qa environments. The 10Gb connections will be back-to-back VPC to two different cisco nexus 7018’s.
thank you
