CA and Identity certs locations
According to for example SOL13946locations for mentioned certs are:
  • /config/ssl/ssl.crt/dtdi.crt - Identity
  • /config/ssl/ssl.crt/dtca.crt - CA
I checked this location on Active unit of Active/Standby pair (11.2.0). No such files there.
However I was able to find this files (or instances?) in /config/filestore/files_d/Common_d/trust_certificate_d/:
  • :Common:dtdi.crt_26612_1 - Identity
  • :Common:dtca.crt_26603_1 - CA
On Standby unit certs are in location specified by SOL. I was nor t able to find any info about this movement of certs on Active - is that by design for HA pair?
Piotr
Seems that it’s not state of the device (Active/Standby) that is responsible for different location of certs. After failover nothing changed, only former Standby have certs in location specified by SOL as well as location I mentioned for former Active. So I am puzzled why there are no certs in location specified by SOL on one device but they are on another. Piotr
i understand we are using the one in filestore but i do not remember where i have read. :slight_smile:
Hmm, so sol is wrong about locations? HA is working without issue, trust can be removed and created but on one device there are no certs in location specified by sol - I ma curious what was the reason for removing certs from would be “default” location. Piotr
i understand it is changed to support introducing of filestore.
OK, I found some references, it’s pity that there is no explanation of changes in DSC docs. Piotr
