Busiest CPU jumps to 100% usage
F5 LTM memory usage id 18.1% and busiest CPU remains between 6 to 13 %. But yesterday and today again I noticed a spike in busiest CPU and busiest cpu rises to 100% while average cpu was 17 at that time.
Can you tell me what could be the problem? I have 2 vs of main traffic. 1 has a lot of traffic and CMP is enable on that one but another one has normal traffic and CMP is disable on that one because Server administrator was demanding exact round robin and not 2 requests on one webserver. Could that VS be producing this kind of spike?
How can I trouble shoot it?
i mot sure that load on vs an cause such issue, mostly i prefer to check the current software release and HF, also seek the release note might you have some setting is not compatible with the current release
its 11.4.1 HF5. Yes load doesn’t increase when i observe the spike and spike most of time reaches bw 90 to 100% although average is 17 at that time but which cpu goes this high and how to find this one.
It can be anything. Check the logs and look for repeating logs. There can be problems like nodes flapping, OS bug anything.
show sys log ltm
If you see something fishy open a support case.
how to check last logs so that I can check right at that time, command like tail -f. There is command show sys log ltm lines xx.
is it happening while you do something on the f5? are you creating UCS backups when the CPU spikes?
below link might be helpful for logs 404 Page not found | BIG-IP Documentation
tail -f does work in F5 but it has to be in the bash not in tmsh so you have enter something like below. run util bash tail -f /var/log/ltm
No I am not taking UCS backup which busiest cpu spikes. And whenever it spikes it spikes to 100% otherwise it doesn’t spike. It does not happen very often. Average at the time of spike is 18%. Could this be the CMP disable at one VS out of my two VS.
During creating QKVIEW file I experienced the busiest cpu to 90 and average 20%. Why cpu is not equally divided? But get these spikes during times when I am not making backup.
SOL15710: Large BIG-IP files may cause the csyncd service to spike CPU utilization - 404 Page not found | BIG-IP Documentation disabled CMP could cause a single CPU to spike if something happened to that virtual server - for example, if an irule is applied and one request caused something to go awry, or if that virtual server suddenly had a high number of connections. You should open a support case.
Yes I have proxypass iRule applied to that VS on which I have disable CMP. I am thinking of enabling it back
