Bulk import SSL keys and certs from cisco ACE
Hi all,
I have to migrate lots of virtual servers from a Cisco ACE to an F5 BigIP V11.2.1.
On the ACE, there are several hundred pairs of SSL Certs and keys that I want to bulk import into specific partitions of the BIG-IP.
I managed to extract all the certs and keys from an backup tarball of the ACE and have them stored in an temporary directory on the BIG-IP.
Now, I want to bulk import them using “tmsh install /sys crypto” commands. The problem here is, I want to have them installed in different partitions. Hence, I cannot create a small shell script reading
tmsh install /sys crypto key key1.key
tmsh install /sys crypto cert crt1.crt
tmsh create /ltm profile clientssl foo bar
because that would put all the config items into the /Common partition.
I also cannot create a merge file for use within the tmsh shell (after changing the partition), because “install /sys config merge” will not accept “install” commands.
Anyone experiencing the same problems? Any hint is appreciated! many thanks in advance!
Martin
I obviously tend to think too compilcated…
tmsh install crypto key /partition/keyname keyfile.key solved the “problem”…
