How can I build the string in the APM VPE from a passed variable? I can get the string without the value, or the value without the string, or the string with the [mcget…] text imbedded, or a TCL error… (I’m pretty sure that TCL quoting is FM)
session.custom.client_proxy contains either a 0 or a 1, and the resulting string should be:
1
I currently have this as the expression in the VPE for the resource assignment:
config.connectivity_resource_network_access./Common/GE_VPN_ST_na_res.client_proxy_settings =
expr { " [mcget {session.custom.client_proxy}] "}
or this:
expr { " "[mcget {session.custom.client_proxy}]" " }
or this:
expr { [mcget {session.custom.client_proxy}] }
or this:
return { [mcget {session.custom.client_proxy}] }
All result in the following error in the APM log:
Variable Assignment Agent: In agent '/Common/GE_VPN_IC_v7-assign_resources_act_variable_assign_ag',
session variable 'config.connectivity_resource_network_access.VPN_res.client_proxy_settings'
not created due to invalid TCL Expression
Whereas this:
return { " [mcget {session.custom.client_proxy}] " }
Returns:
(I suspect that the XML tags get eaten by the browser displaying the Message Box it was in)
Help!
-- Stan
