Hi All,
I would like to know the possibilities to protect a webserver,against bruteforce attacks, who uses JSON parameters. In the ASM, the default option is, to protect a loginpage. The webapplication we want to protect, uses JSON parameter. The request looks like this :
Content-Length: 84 Proxy-Connection: keep-alive Content-Type: application/json; charset=utf-8 User-Agent: [ics]:[iPad]:[2.1]:[20141103]:[1]:[Retina] Connection: keep-alive
{“cardPostFix”:“0097”,“postalCode”:“1112CN”,“houseNumber”:“5”,“expiryDate”:“08\/18”}
There is a possibility to do something with JSON (JSON profiles) but this concentrate on only the data and lenght that passes the ASM. Not bruteforce.
Is there a basis iRule for this to exam this kind of mitigation. I looked for some and find one(POST Request Exponential Backoff), but I’m not sure this is the right way to implement a bruteforce mitigation.
Thanks in advance. Erwin
Can you clarify what your definition of a brute force attack is please? Are these POST requests? Is a HTTP error returned? Are you more concerned about multiple valid requests but over a short time period etc. etc
Hi. The definition of these bruteforces is protect the webserver from multiple request (valid or not valid) from one source in a short of time. The are certain POST request.
Hi Erwin, you should be able to configure protection against multiple requests from a single source by configuring a login page and then defining thresholds for it. I don’t think you need to worry about JSON parameter complications for this. In ASM, go to Application Security>Anomaly Detection>Brute Force Attack Prevention, and then create a page that you want to protect. You can specify exactly how many attempts from the same client will be allowed.
Have you looked at Project BAIU? F5 is considering hard baking this into the product still. It was designed for brute forcing and is proven to be incredibly accurate and effective plus you can configure just how basic or advanced you want it. The user ID extraction iRule focuses on forms and normal parameters to extract user IDs. If you want it to do JSON, then change one of the string maps “string map \x2D\x2D\x2D\x2D\x2D \x26” to "string map \x22\x3A\x22 \x26 and then you’ll be parsing out JSON data and rate limiting it i.e. preventing brute forcing and heavy hitters. marclebeauaz@yahoo.com if you need more info about this suite of iRules.
Project BAIU on DevCentral
Project BAIU Home Page including the 5 million IP/network blacklist
