Hi All,
I would like to know the possibilities to protect an website,against brute force attempts, the site uses JSON parameters. we are using ASM version: 11.6) ,i know v-12 got json authentication in login page creation which will help us out.But the version upgrade is still under consideration.. any suggestions on this brute force mitigation for JSON in 11.6 v? thanks
It appears that there two options. Ideally, upgrade to 12.x and use the JSON brute force mitigation. On 11.x, you would have to either build a custom iRule to handle this. A quick search on devcentral shows:
You could use this as starting point. If you are unable to customize this please check https://f5.com/support/professional-services/consulting-services/irules-ondemand
Alternatively, you could try to detect the brute force login attempts using DOS by limiting the number of Requests from a given source ip.
