BrowserMetrix JavaScript snippet using F5 BIG-IP appliances
Hello,
On of my app needs the following> The VIP serves many applications. How do we set so one 1 app get this injection. i.e /newapp
The irule for this vip would be: when RULE_INIT { set static::jscript { } }
when HTTP_REQUEST { Disable the stream filter by default STREAM::disable set uri [string tolower [HTTP::uri]] }
when HTTP_RESPONSE { if { [HTTP::status] == 200 } { if {[HTTP::header value Content-Type] contains “text”} { set stream_find “” set stream_find_lower “” set stream_repl “” set insertJscript 1
Do not allow the Javascript insertion if the pages end with the following
        switch -glob $uri {
            "*.ashx*" -
            "*.asmx*" -
            "*.axd*" -
            "*.js*" {
                set insertJscript 0
            default {
                if { [HTTP::payload] contains "META HTTP-EQUIV=\"Refresh\""} {
                    set insertJscript 0
        if {$insertJscript == 1} {
            append stream_repl $static::jscript
            append stream_expression "@$stream_find@$stream_repl$stream_find@"
            append stream_expression "@$stream_find_lower@$stream_repl$stream_find_lower@"
            STREAM::expression $stream_expression
            STREAM::enable
